different cyclic pitch
Posted: Sun 25. Sep 2022 16:42:58
by nichtdiemama
Hi
I'm setting up an Heli for F3C and I would like to use different cyclic pitch for different banks.
For example Hoovering 4,5 degree, Normal 8 degree and Landing 6 degree.
How can I do this settings?
As far I can see the cyclic ring is fixed for all banks.
Re: different cyclic pitch
Posted: Sun 25. Sep 2022 18:27:14
do you want to achieve different rotation speeds?
If yes, then it is enough to set different Rotation Rate for each bank.
If the aim is to change precision of steering between banks by lowering throw, then this is the correct way.
Or you can use transmitter settings and dual rates.
Posted: Sun 25. Sep 2022 22:56:45
by nichtdiemama
My aim is it to get a setting with the most precise steering for hovering.
Posted: Mon 26. Sep 2022 7:28:41
Then set Rotation Rate in the Sensor Tab to the lowest value and also set Flight Style to 8. This should make it the most precise.
Posted: Mon 26. Sep 2022 7:48:16
by nichtdiemama
Thank you for the quick response. I will test it.
Posted: Sun 30. Oct 2022 12:31:51
by nichtdiemama
Hello
Like you advised I set the Rotation Rate to the lowest and the Flight Style to 8. The feeling became a bit better.
Kind regards
Jens
Posted: Tue 01. Nov 2022 8:08:25
You can also decrease Cyclic Feed Forward to get the most precise control. With values 3-4 it should be super precise.
