Specter V2 tail issue
Posted: Wed 19. Oct 2022 9:48:08
i use the Spirit RS in my Specter V2 with a GDW995 Tail Servo and 115mm blades. The tail turns slightly with the torque at pitch pump input at any rotationall speed (1400-2200 rpm). I changed all parameters (delay/revomix) but can't solve it completely. The issue went better with increasing the Revomix. Now the parameter is at 4. The delay is at 2. I talked in the RC Heli Forum about the issue and 2 other Spirit users wrote that they have the same Problem with another Specter V2 and a Protos 380. They tried also everything.
My tail mechanic slides super smooth and the Tail pitch sleeve uses almost the hole way of the rotor shaft. Controller is a YGE Aureus. When the Tail does not hold during hard Pitch input the Aerobatics can't be flown perfectly!
Maybe with higher values Revomix over 4 the issue could be solved!?
