Setup 2 different rescues
ExCCHP
Let me start by stating I have the Spirit GT bound to an NX8.
I would like to to setup 2 seperate rescues on 2 seperate switches.
1 would be rescue acro on the momentary swtich ( Sw I). Purpose to level the heli disk in either upright or inverted
2. Would be the active auto rescue and establish the hard deck limit on a 2 position switch (Sw A)
The auto rescue I have setup already. Since they are both a selection on the stabi tab, I am only able to figure out how to have one active at a time.
Is there a way to accomplish this?
ExCCHP
NM I got it
Had to update the Spirit unit. Then select "select by channel " in the stabi tab. From there assign desired function in the channel window.
All seems to work on the bench. Will test it out at the field later today
