And we have noticed again how well the SPIRIT GT works, the Heli flies like on Rails, the control and feedback cannot be better, and that even I have the setup at maximum full 3D gain, even the Geometry Tuning that normally are on 6º, I setup to the maximum at about 9.7º.
I have tried many, if not all Flybarless systems and much more expensive, but none is as perfect as the SPIRIT GT!
The Pilots in our Air Club no longer use the Flight Simulator when they test or training a new maneuver,
they simply put the Virtual Net, and more than one Pilot has saved the Heli several times of a hard crash!
Now I would say that it only has a little fine tuning left, for example the RTH,
the Heli wobbled a bit, but I think because the speed of Return Home is a little bit to fast, and when braking
to the Position it goes into ocillation.
On the Virtual Net, a little bit fine tuning will be perfect, also more precision, ok I know we will never get
Military precision on the GPS due is is capped for civil use.
Another improvement would also be good for less experienced Pilots, in the manual Bailout, here it would be a good idea, of override the user Pitch stick control after making the rescue , for about two seconds,
since the Pilot, in a bit of panic, forgets to raise the yoystick to positive º again, and otherwise consequently the Heli pulls down to the ground fast.
Congratulations, some Manufacturers after taking it out like Skokum that cost almost 800 Euros failed,
after a short time, other European manufacturers announced with the presentations of their new Flybarless Systems,
that in the future they wanted to also take out the GPS modul, which as it has been seen they have never done , because they know that it is very complicated.
Not mentioning the Chinese, that the only thing they know is to copy , and with a very bad or not at all quality!
Well, this winter it's time for the Update Project to assemble the SPIRIT with the GL V2 in my Big Airwolf Turbine and 100 Scale interior and exterior, I'm looking for main Rotor Heads, I don't know yet with four or five Blades, what do you think, now it only has two Blades with Paddel.
The Heli weighs around 16 Kilos.
https://www.youtube.com/watch?v=V3y6_UfOATM
