Jeti BIN-File 3.4.3?
Posted: Thu 03. Nov 2022 7:28:50
by Michldigital
Situation: BIN-File 3.4.1 (Jeti) , 3.4.3 GTR.
If i change some values over the DS16, some settings didn‘t save.
When will you release the 3.4.3 BIN-File?
Greetings
Maik
Re: Jeti BIN-File 3.4.3?
Posted: Fri 04. Nov 2022 15:44:27
by michil
Same for me. One of the main features (controlling via TX) of Spirit GTR isn't working.
Very bad. Just bought the GTR as the second device. My Spirit GT isn't working either (also on 3.4.3).
Please update the SPIRIT.BIN file for the Jeti transmitters.
Kind regards
Michael
Posted: Fri 04. Nov 2022 17:12:01
if it does not work it mean that your BIN files are not at 3.4.1, but much older.
It should work for sure with 3.4.3 firmware with no error.
We are configuring our Spurit units exactly with these BIN files.
There is no reason to make any update of them, so they are still same as for 3.4.1 firmware.
There are now even videos how to do update of the files correctly, because many pilots thinks they ate doing it correctly, but it is wrong which is reason why you are getting error.
What ERROR do you see or which parameters cant be saved?
Posted: Fri 04. Nov 2022 17:36:33
by Dan0111
I have also told you several times that it does not work. I still have the same problems as I have had for a long time. I am definitely on 3.4.3.
What could you possibly do wrong? You download the files, unpack them and copy and paste them into the device order on the Jeti.
Replace files? Yes! Done!
Or not?
I don't know what else to write about it. There are a lot of people with this problem and they can't all be unable to copy the files properly. It would be nice if there was finally a solution instead of just saying you are not up to date with the .bin.
regards
Daniel
Posted: Fri 04. Nov 2022 19:03:58
by Michldigital
Some Parameters are saved. But Not all.
For example Servo Direction, Servo Mid-Point are not saved.
Jeti Bin 3.4.1 and Spirit with 3.4.3 isn‘t working! So it is!
I know exactly how to Update a spirit and a Jeti Transmitter correctly!
And i‘m Not the only one where it doesn‘t work.
So please update the Jeti bin file.
Posted: Fri 04. Nov 2022 21:10:31
I will record video on monday from settings.
Please make sure to have Bank 0 configured.
Posted: Sat 05. Nov 2022 8:10:56
by michil
ZeXx86 wrote:Hi,
thanks for this hint. I was shure that I had the 3.4.1 version on my TX. I downloaded it again and first thing I recognized was the file name. There was a „R2“ in it. I downloaded it to the TX and the silly warning when selecting the Spirit tab is gone.
Thanks a lot for your help.
Michael
Posted: Thu 10. Nov 2022 10:45:47
by AndrewJohnHawes
I am trying to get the usual on-screen set-up display in Spirit-Aero, with a SpiritGTR, that I get with the non-GTR Spirit units in Spirit-Heli. If I use a GT, for example, with a REX3 receiver on a heli, the set-up comes up in Device Explorer very nicely.
I can get the set-up parameters with the Jetibox Application, but this is not quite the same or as easy to navigate and use.
In Device Explorer with the SpiritGTR I get REX-RS and none of the usual set-up steps like I get with the Helis. Is this a function of the GTR or just the Spirit-Aero?
Thought I was doing something wrong, but maybe just the way it is?
I think this might be what some of the other guys are saying?
Regards,
Andy
Posted: Thu 10. Nov 2022 11:00:24
this is not supported by Spirit Aero, because it was not allowed by JETI until now. Fortunately we moved things forward and they accepted to release the files developed by us. So you can expect similar integration files for Aero very soon too.
Now you have to use JETIBOX as described in our aero manual.
Posted: Thu 10. Nov 2022 12:50:11
by AndrewJohnHawes
Thank you ZeXx86!
That is what I had sumised.
Look forward to all new releases, thank you!
Regards,
Andy
