RTH setting different in 2 places on windows
Posted: Sun 06. Nov 2022 17:21:57
Hi, i must say RTH and Geolink other features always saves the day ! I have 2 bank configured with RTH and Geofence for 2 sites i use it the most. I want to use bank 2 to configure a RTH when i just drop in a site i don't fly often. I like the feature to enable configure of the RTH by bank and did change my settings in the radio to support this new feature.
However, theyre is a difference when i configure this percentage setting in the geolink VS the servo windows.
In the documentation,
1.3.1 On (1)
Channel value 57% - 100% : When On (1) - RTH is ON
1.3.2 On (2)
Channel value -100% - -62% : When On (2) - Change will affect all Banks
1.3.3 On (3)
Channel value -61% - -38% : When On (3) - Change will affect only active Bank - if Bank Switching is used
1.3.4 On (4)
Channel value 27% - 56% : When On (4) - programmed automatically during each Take-Off.
When i programmed my radio Spektrum IX12 using SRXL2 i was not not seing the right message in the Geolink windows it is writing Active (programing all banks). When i change to the servo window it says On (3).
Theyre should be the message (affect only one bank) in the Geolonk window it seems like a bug and could affect users using that feature with geolink window to validate.
I tried it on a site and the servo windows for On(3) has the correct reading.
Can you confirm you are seing this as well.
Thanks !
Pierre
I am adding two screen snaps to the message servo window and the geolink window.
1.3.1 On (1)
1.3.2 On (2)
1.3.3 On (3)
1.3.4 On (4)
Thanks !
Pierre
