Spirit GTR and Frsky
proctormw
New to Frsky and trying to get R8 Pro receiver and spirit GTR to talk to each other. Any help would be appreciated. Thanks
I am afraid but it will not work.
Spirit GTR is only for JETI DUPLEX radios.
Spirit GTR has itself built in receiver.
For FrSky it is needed to buy Spirit GT or Spirit 2.
There is possibility to make it work with FrSky radio if you can install JETI DUPLEX TU2 module to your radio.
Then it can be used for flying. But it require to change channel mapping and ranges.
proctormw
OOPS. It's a Spirit GT.
Ah, great.
It is enough to connect S.BUS with RUD port with supplied cable.
The wiring diagrams are in our manual and also in the Spirit Settings software.
If you want also integration then you need to connect another cable if using S.PORT, but specially modified.
See this page:
https://manual.spirit-system.com/index. ... #Spirit_GT
