[ Version 3.4.4 released! ]
New version 3.4.4 released!
  • Increased Gear Ratio range in the Telemetry window:
    • Gear Ratio range was increased to allow a proper settings (1 - 32 ratio).
    • Goblin RAW 420 and similar models can configure correct Gear ratio in the Telemetry window, same as in the Governor window.
  • Spirit Settings for Linux on QT5 library:
    • Spirit Settings software is using more recent library now.
    • Compatibility on a different Linux distribution was improved by this change.
  • Spirit Settings for Mac OS updated:
    • Spirit Settings on some Mac systems was not showing GeoLink map properly.
    • Libraries for Apple Mac systems were updated to support more image formats.
  • Spirit Settings on a small screen:
    • Spirit Settings with screen resolution such as 1440 x 900px will fit all content properly with all Operating Systems.
  • HobbyWing v5 telemetry:
    • Telemetry variables were showing 10 times lower values on some v5 ESCs.
    • Current and Capacity measurement was fixed.
  • GeoLink logging:
    • Logging is enabled when unit will detect vibration level 3% and more.
    • With some models logging was interrupted when vibration level was too low.
  • RealTime logging:
Update for the Spirit Settings software is available in our Download section.
New firmware for the Spirit units is available online directly through the software.
NOTE: No changes in the settings are needed after update from the previous version 3.4.3.
