Spirt GT
treys1
Hello, playing around with a Spirt GT after ~3 off from Helis (but several years with Spirit 1 & Pros), and I just want to confirm the following config is OK.
F. Stabilization (Normal) - 7. Channel
F. Rescue (Automatic) - 8. Channel
F. Rescue (Normal) - 9. Channel
Only reason I want all 3 is that I am still getting comfortable after a few years off and want to have the Stabilization available JUST if I have orientation issues while flying and need help getting my bearings to bring it back.
Thought process is take off, enable Rescue (Automatic) for the hard deck and use Rescue (Normal) if something happens above the deck, WITH Stabilization there just in case its needed, but to rarely use.
To clarify, I have already set up and tested:
And it worked just fine, was hoping to add the Rescue (Normal) in there as well.
yes, your settings looks good. It can work in that way.
treys1
Thanks!
