geo link problems
neils
Today i tested my new build sab goblin 420 with geolink,
when I switch on altitude limit ( safety net ) at about 4 meters the helicopter shoots up and does not stop ! I only just managed to switch off and recover.
I have the same setup on my goblin 580 ie designated channel and state 1 with no issues.
I have checked the setup several times but it still does it. Do i need to hover for longer before engaging ?
there will be only problem in configuration.
Please attach your configuration file and I will check it.
neils
Today I tested my Sab 420 with Geolink V2, before the test I deactivated all functions on the geolink except for altitude level (ie the net ) but still the heli goes up and up without stopping when I activate the switch in state 1
I also test my Sab 580 today with Golink V1 with perfect result, no problems and yet same configuration .
My setups are the same ! there must be a problem with geolink V2
I also have a Sab Genesis with Geolink V2 and this also goes up up up without stopping when i activate the altitude level switch.
It appears Geolink V1 works good but not V2
Thanks for your help
Neil
Rider4490
Hi all
Same Problem here
on both Geolink V2 and Spirit GTR as soon as i activate it on the Spirit GTR Geolink is off it Shoots up with no Stop.
The same for GEolink V2 function turned off in the SPirit GTR Heli Shoots up with no Stop
This can happen if more functions are enabled.
Please unassign and disable all unused functions. Then it will work.
Or you can send settings file and I will tell you what is wrong. Very likely there is stabi function.
Rider4490
Hey give me 10 minutes and i will sen you here both setting files from both soxos helis
Rider4490
This are the files from Soxos V2
BANK3 Soxos V2.4ds
(255 Bytes) Downloaded 287 times
BANK2 Soxos V2.4ds
(255 Bytes) Downloaded 251 times
BANK1 Soxos V2.4ds
(255 Bytes) Downloaded 276 times
Rider4490
Those 3 files are from the Soxos V1
BANK3 Soxos V1.4ds
(255 Bytes) Downloaded 279 times
BANK2 Soxos V1.4ds
(255 Bytes) Downloaded 247 times
BANK1 Soxos V1.4ds
(255 Bytes) Downloaded 274 times
Rider4490
ZeXx86 wrote:This can happen if more functions are enabled.
unassigned all stabi funktions doesnt work
I can see that there are almost all functions assigned.
Because there is very high chance some function is engaged together with Altitude Limit I recommend this:
1. Unassign ALL functions from Special Functions in the General - Functions, leave only F: GeoLink Altitude Limit
2. Turn off ALL functions in the General - GeoLink - Aid Tab, except Altitude Limit.
After this change I believe it will work well. Then when you will be sure it works as expected, add other functions. But make sure that all are disengaged - value 0 in the General - Channels.
