Flashing Light and Beeps on Spirit RS
Acrow
I have just acquired a heli which has a Spirit RS. I have bound it but haven't been able to connect it to the app. It has a double flashing light and beeps. I have checked the on-line manual but couldn't find a description for these codes.
Where should I be looking?
The Spirit unit has no way to beep.
Can you send an ideal video? Or at least a photo of what kind of heli you have and how it is installed?
Acrow
Thanks for the tip. I was powering the unit with a 2S battery. The beeps were coming from the motor as the ESC was sensing low voltage.
I'll try it using the normal power battery and bec.
What Status LED of the Spirit RS is doing? You should be able to connect once it is steady ON.
