.Lua scripts for EdgeTX.
Vector
I came across this log viewer - https://github.com/offer-shmuely/edgetx-x10-scripts, can we utilize this viewer with Spirit's integration scripts ? I've try to run this viewer but can't put it in tools folder unless it will replace Spirit's log viewer. From my understanding Spirit's scripts are tailored. Look like it come down to common script names.
Aquaaddict
Yes I use that log viewer on my TX16, works well to chart the values from a flight. Just rename the .lua file to whatever you want to call it and put it in the same scripts folder.
Vector
Aquaaddict wrote:Yes I use that log viewer on my TX16, works well to chart the values from a flight. Just rename the .lua file to whatever you want to call it and put it in the same scripts folder.
Thanks. Will have to try.
