[SOLVED] Rudder Servo
Taco88
I was able to hover my Gaui X4II, very stable. The problem is the tail is reversed, when I yaw to the right the tail also turns to the right. Do I adjust this on on the radio or on the Setup Wizard Step 6 Servo Operation settings? Thanks!
Marcus
You have to change reverse in your transmitter. Just reverse rudder channel. Then all should be OK.
Taco88
Thanks! I'll do that.
