[ Version 3.5.0 released! ]
Posted: Mon 13. Mar 2023 12:09:56
New version 3.5.0 released!
New firmware for the Spirit units is available online directly through the software.
WARNING: Please be aware that GeoLink's function Altitude Limit behavior has changed. Check settings in the Spirit unit.
- Added full support for FrSky F.BUS protocol:
- New support for F.BUS protocol that carry telemetry and integration in one cable.
- Possibility to connect F.BUS compatible telemetry sensors.
- Support is available for Spirit Pro, Spirit 2, Spirit GT.
- Wiring for Spirit Pro and Spirit 2 require FrSky integration cable.
- Wiring can be found in our F.BUS guide.
- Improved support for FrSky F.PORT protocol:
- Support was added also for microSpirit, Spirit Pro and Spirit 2.
- Wiring can be found in our F.Port guide.
- Improved support for FrSky S.PORT telemetry and integration:
- Improved support with some FrSky ACCESS receivers.
- Avoiding telemetry lost messages.
- Support for 24 channel JETI EX BUS protocol:
- JETI radios can enable 24 channel mode from now.
- It will work correctly in the same way as with a standard mode.
- Support for Instant boot with recent Spirit units:
- New feature that will allow instant booting after Flashing (apply for updates from version 3.5+). Unit will boot up without waiting.
- When unit will loss voltage for short time it is able to fully recover instantly when flying enhancing safety.
- Spirit GT and Spirit GTR: Improved safety when unit is hit by a very strong static dischage. In this case unit is able to recover when flying avoiding crash.
- RealTime logging - Auto cleaning:
- Added support for automatic Log cleaning during take off.
- You can avoid full memory with this option.
- Unit will carry log always only from the last flight with this option.
- New Option is available in the Log Configuration window.
- RealTime logging - New Clear Log behavior:
- Logs are erased smoothly without interrupting operation of the Spirit unit.
- Progress of the Erase operation is displayed in the RealTime Log window.
- GeoLink Altitude Limit:
- There is new parameter called Altitude - Low Limit. This parameter will replace Mode (2).
- By default it is configured to 0 which will result in normal behavior from previous version.
- When value is non-zero you can define Hard Deck limit directly in the software.
- Altitude is zeroed when vibration level is under 2%. This can improve Altitude Limit precision with some models.
- GeoLink - ISP coordinates:
- Coordinates are obtained from different provider which will improve reliability.
- HobbyWing v5 ESC telemetry:
- Fixed current and capacity measurement with some models.
- Spirit Settings under Windows:
- COM port names do not contain any slash character.
