Spirit Fail Safe
Acrow
Hi
I have an RS2 Spirit and it is my first Spirit unit. I want to set up fail safe so it brings the throttle to the throttle hold value and maintains all other channels at their current values.
I have got the throttle channel to my required value however I can't find in the documentation how to set other channels to maintain current value.
Is this possible?
You can set Failsafe by pressing Failsafe Button in the General - Channels window.
The only option is to set channel value.
Configuration to hold last value is not possible. It is not there because model with FBL will continue in its movement. Instead when you set channels to center the model will remain in the last position which is safer.
Acrow
Thanks for the quick response and clear explanation.
