[SOLVED] Integration - EdgeTX but with Spektrum RX
beserkr
Spirit Integration Possible? - EdgeTX RM TX16S MKII | Spirit FBL | Spektrum SRXL2 4651T & 9747 RX
Exactly as in the title.
I've recently switched from a balky and unreliable Spektrum DX9, to a beautiful, solid Radiomaster TX16S MkII w/ AG01.
Thing is, both my 550 and 700 helis are rigged with Spirit FBLs and Spektrum SRXL2 receivers; - the 550 has a 4651T coupled with a single 9747, where the 700 has two 4651Ts.
I've successfully flown the 550 with the TX16 bound to both the 4651T and 9747. However, I can't get Spirit integration working (I've not looked at telemetry yet). Integration worked perfectly on the DX9.
I'm using the lua script found here https://www.spirit-system.com/dl/opentx ... 4.3-en.zip (using the Horus X10 one since it has the same display size as the TX16S) and it loads, but all values just show zeroes whatever I try.
Is the issue setup/user error, or will I need to replace all of my Spektrum receivers with FrSky receivers?
Many thanks in advance.
It will not work. OpenTX and EdgeTX has no support for this with Spektrum receivers or any other than FrSky or at least RadioMaster.
beserkr
Thanks for the quick reply Tomas.
I thought that would be the case. I'll start shopping for FrSky/Radiomaster receivers!
