Spirit Settings (on PC) - Allow multiple instances
jjuk
Spirit Settings application only allows a single instance to be opened. This makes copying settings tricky. Can it be changed so that multiple instances can be opened, and if an instance is already connected to USB, open the 2nd in demo mode instead.
what settings do you need to copy?
If you need to copy settings from one unit to another, why you will just not save the files and then open them in the second unit?
This process takes just few seconds and can't go wrong.
jjuk
I've changed receiver type from sbus to fport. All channel settings and stabi settings were lost so I'm trying to copy from a recent backup.
