[SOLVED] SAB Urukay 3 Blade Rotorhead
Amdxp
hello
I have a question I own the Spitiz Flybarless and put it in a SAB Urukay with 3 -blade rotor a .
There are now special parameters necessary or you can set it the same as in inem 2 blade rotor .
Can you come down with the gain on a 3 -blade rotor or left as shown in the instructions
Best thanks for your answers
you can use 3-blade head without any problem.
Cyclic Gain can be probably same otherwise you will need little bit lower gain.
I recommend to decrease Cyclic Feed Forward (for comparable flight characteristics) with 2 blades and also to increase Rotation speed, little bit.
