Altitude Hold and Throttle Curve
MichaelT1960
When you engage altitude hold do you also need a constant (gov mode) throttle curve so that low stick is not off?
Otherwise you would be in trouble at lower stick.
franz88
the governor it just works from 51% of throttle curve to the 100% throttle curve.
indeed if you go GENERAL-GOVERNOR-SETTINGS
you will see that request rpm it is activated only from 51% onwards.
from 50% to 0% the governor is deactivated
MichaelT1960
What if I am using my own governor curve on my Futaba T18szh transmitter?
Do I need to make sure it it is flat from 0 to 100, or does the Spirit 2 automatically take care of that?
Thank you, Michael
vvv850
Please go through the governor setup page to better understand the concept: https://manual.spirit-system.com/index. ... e=Governor
You will need a FLAT curve above 50%. A flat curve means ex 60% 60% 60% 60% 60%
