Scorpion Tribunus 14-200 Telementry not working
I followed the Spirit GT manual for Tribunus II ESC, Futaba R7003SB S-Bus receiver, and Futaba 14SG Transmitter for telemetry set up. The sensor page in Tx shows 8-16 slots with Kontronik listed. When I power everything up the Tx in the telemetry page shows the various telemetry parameters but no values. What am I missing? Please help. Thanks.
how is your receiver wired?
Are you using SBUS2 slot of the receiver?
Is Scorpion set for correct telemetry protocol?
Is Spirit set for Scorpion telemetry?
Are you using Telem UNI cable for telemetry between Spirit GT and ESC?
Yes to everything except I am using Port 1 S. Bus from R7003SB Rx to RUD port in Spirit GT instead of S Bus2. I couldn’t seem to get a connection when using S Bus 2. This is probably my problem. So I should using the Sbus2 port for my primary connection to the RUD port in the Spirit GT unit? The Spirit manual was not clear on this. Thanks.
It is needed to enable the SBUS output. By default it might be off.
It should be explained in the receiver's manual.
Customer, user brain malfunction. I had the connector reversed (polarity) when I switch from the Sbus port to the Sbus 2 port. All telemetry working now. Really appreciate your help and time to point me in the right direction. Also The Spirit 2 is flying good.
