[SOLVED] bank switching not working
djhandz
Hi spirit crew i am setting up my 3rd unit on a gaui x3. Problem is i dont seem to be able to switch between banks. When connected to the software the diagnostic page shows the bank switching from 0 to 1 to 2 as i flick the 3 pos switch on my dx8 but when i test fly i get no chance when flicking my 3 pos switch
I have it set up as bank 0 normal bank 1 Stabalisation and bank 2 rescue any suggestions would be appreciated thanks
Compass 7hv v2 spirit pro. Compass 7hv v2 spirit pro. Trex 550fl spirit. Heli-x sim. NeXt sim. Pheonix sim. Fms p51 1400 spirit. Coolice 2400watt psu. Pl6. Icharger 206. Peter lynn twister 5.6. Dx9. TM1000.
most probably bank switching is working correctly, but to activate special functions, your gyro gain must be negative.
So even your gyro gain is configured in the software, you have to set in the Sensor tab negative gyro gain for Bank 1 and 2.
Then you can test it on the bench, so it should work without any issue.
djhandz
Thanks tomas thats it totally forgot that bit lol
