Can some one please explain how to setup !!!!!!!!
satnaam
Can someone please take some time to explain and show how to setup the rescue, stabilization and bank switch? This unit is very good but lagging proper instructions with examples.
Thank You
satnaam
Rdlx3m
satnaam wrote:Can someone please take some time to explain and show how to setup the rescue, stabilization and bank switch? This unit is very good but lagging proper instructions with examples.
Thank You
satnaam
I fully support you on that one! Should be more pictures explaining how to!
But what you going to fly? You dont need bankswitching to be honest. Bankswitch does not work how i want it to like a "different profile" . Just some functions change as i understand. So you can keep on bank 0 and just add your desired functions under "channel" button on page 2 in the app.
Geolink rescue/return to home, stabi function, just link it to a switch you want. Remember that there is several commands within same function.
For example, return to home has 3 or 4 different actions depend on % of switch you give. If you switch is -100% its off. If you have 0 its one function, 60% one function .. so on, if it makes any sense?
