[SOLVED] Swapping spirit with spirit 2
ianboom
I've just bought a TREX550X and have a fitted an early Spirit FBL to it (the version with vertical pins).
The canopy sits on the connectors. The Align servo plugs have moulded shrouds on them which makes the issue worse!
I have a Goblin 500 with a Spirit2 (has the horizontal pins). The Goblin looks like it will fit the older Spirit, so I'm thinking of swapping them.
My question is, if I save the settings for each unit, swap them and reload the settings (changing FBL orientation) will they work without any further programming? I can't see why not, but want to double check!
Also, can I run an SRXL2 RX and a satellite on the early Spirit?
yes, it will work with no change.
SRXL2 is supported with all Spirit units.
ianboom
Thanks for the info.
For anyone else who needs to do it, the software keeps the correct orientation of the Spirit unit!!
