I have a Spirit unit. The original with the servo pins coming out the top with a problem.
I had it connected via sbus to my FrSky receiver in another heli. I updated its firmware and installed it in another heli. I cant get it to see my receiver via sbus. I have it set to Futaba Sbus in the wizard. I have tried several receivers.
This unit hooks up with the sbus adapter cable. It worked fine before I moved it. I suppose I should try another adapter cable?
I did hook it up the old fashioned way to my received (PWM I believe) and it functioned that way after changing to PWM in the wizard.
