Swash creeping forward on ground
Posted: Sun 06. Aug 2023 12:09:08
I have an original red Spirit that flies well, but noticed and unusual issue this year. Before spooling up, the swash will very very slowly tilt forward. So slowly that takes 20 - 30 seconds to fully tilt. I can level it using the elevator stick before taking off. Once flying I haven't noticed any issues and the heli flies like on rails.
However, most times after initialization, this behavior is not there, meaning the swash will self level as normal on the ground, even after moving the cyclic sticks.
This strange behavior happens only sometimes, but when it does happen, it exists until I cycle power, then it could be gone.
I have tried:
-increasing flight style to 4 in all banks
-increasing dead-band in the unit to the max
-resetting unit to factory settings
Any ideas on what could be the cause?
I'm always carefully to make sure the heli is still during fbl initialization.
I have tried:
