swash problem
Martin.S
wel i got a spirit2 with geolink fw is 3.5.0 :D :D :D
try to get everything to work but on Frsky s-bus its not working :o :shock:
so i turned over to normal use with the TD-R10 reciever to PWM mode
after many try's erverything fanaly works. :P only swash leveling on rol function is stil wrong :shock:
when tilting the heli to the right or left the swash must be stay level :!:
but now it rising even more to the right or left so this wrong.
i tink reversing servo on the Frsky tandem X20 will do the trick.
but no that's not :( .
Q:how to revere stabilisation on the roll function and keep al the rest the same.(this is working in the wright derecrtions)
reversing on the TX ore in the Spirit software do not work. :?: :?: :?:
regards Martin
the issue could be in the settings of the mounting position, swashplate type, servo reversing in the unit or in the radio.
We recommend to carefully proceed according the Setup Wizard.
Make sure each channel is moving in the right direction for aileron, elevator, pitch, rudder in the Diagnostic tab first. This must work always well.
