Switch Assignment (Jeti DC-14)
Heliman550
Hi there, I would like to have some feedback on assigning switches to make most use of my DC-14 transmitter. Up to now, I have kept everything very simple and not used switches to select within functions.
I currently switch my 'Banks' via a 3-Position switch on the Cyclic Stick. There is also a 2-Position 'Throttle-cut' switch fitted to the Collective Stick. 'Stabi' options are done on the ground via 'Device'.
I have switch Sa (spring) to rescue when training. I hardly ever use a 'Stabi' function but now that I have a GeoLink I will need to use 'Coaxial' from the 'Stabi' options. How should I set up to be able to make use of the different features e.g. 'Return To Home', 'Altitude Hold' etc.
I have upgraded my Firmware so that I can now take advantage of being able to programme using a separate channel.
Thanks in anticipation.
Regards,
Heliman550
