Servos Not in Correct Position on Startup
davidbitton
The three Torq BLS2208 servos I have attached to my Spirit GTR are not starting in the position setup during subtrim adjustment. Also, the servos are not holding up the blades. The servos setup in the correct position w/o blades installed. I even upped the BEC voltage to 8.0; thinking it was a torque issue. Nope. Any ideas? Thanks!
I guess that settings were not saved after your servo setup. For this reason position changed.
Please make sure that settings are saved in the Backup tab by clicking at the Save button.
Or you can enable Automatic saving at the bottom side of the software.
