Nitro heli with RPM sensor for governor
nzlsubzero
Hi All
Is there a way to test if the RPM sensor is working?
I have always used a mutligov for nitros and to test if the sensor is working, you could move the magnet over the sensor and it would then show if it is working.
nzlsubzero
So I found the tester option.
When the magnet is over the sensor, it shows inactive. When the magnet is away from the sensor it shows active. If this correct?
Sent from my SM-N950F using Tapatalk
Yes, this is OK. However it is important that distance is good too if readings are not stable.
nzlsubzero
Thanks.
I would've thought that it should be active when the magnet is close to the sensor.
