Default Spirit II Defective From New, I Think
Posted: Mon 16. Oct 2023 16:43:16
by mcfast
Hi Guys
I got this Spirit II last year but it has never functioned right, I think? I just noticed it lately trying to do a setup on my gasser.
On my T-REX 500, I was able to cheat in the radio to get the 500 to fly, but not the greatest.
This is the problem that I have when I am in the recovery mode or setup wizard when I go to the limits page and adjust the pitch range, I can adjust all the pitch range I need and more, but once I'm unplugged for the PC and reboot the unit the pitch never goes past 5°no matter what I do, pitch curve 100%, servo endpoints 100% the only way I can get a bit of more pitch is to go past, 100% in the endpoints, I am getting up to about 7°, not enough, it was all right for the 500 but not enough for the gasser.
PS I also have a Spirit GT on my Goblin and it works perfectly happy with it, very happy!
Re: Default Spirit II Defective From New, I Think
Posted: Mon 16. Oct 2023 17:27:35
by Mattes61
for help you must give a bit more detailed information -
What receiver, what transmitter, what protocoll etc.
Make some pictures from your setup in the spirit settings and/or crate a .4ds settings file of your configuration in the FBL.
Post the file here in the forum (attachment) -
Another question why have you not informed the costumer support that your FBL is not working correctly ? Why have you waited so long to do something about it?
Posted: Mon 16. Oct 2023 23:04:10
by mcfast
Receiver, Futaba R2008SB, Transmitter Futaba T14SG on 2.4 S-FHSS using S-Bus
"why have you not informed the costumer support that your FBL is not working correctly"
I had it on a T-Rex 500 and by cheating in the radio I got it to fly OK not great, I really noticed a problem when I wanted to set up my Gasser helicopter, that's when I saw the problem just lately, need more than five to seven degrees on the main blades to fly good, I all so have a Spirit GT on a Goblin 700 all most the same setup it is perfect!
Posted: Tue 17. Oct 2023 7:12:51
please share your Spirit Settings file (4ds from Backup tab)
You shared only PDF log. The problem will be related just to the settings.
Posted: Thu 19. Oct 2023 20:41:07
by mcfast
Hello again, I put all the files I could find in the spirit file installed on my PC. Now how do I send them to you?
Do you have a current email address that I can use to send the file?
Thanks in advance
John McDonald
Posted: Fri 20. Oct 2023 20:20:24
by Mattes61
save your settingsfile out of the Spirit Settings Program as you see here:
then load it up here in the forum as attachment:
Posted: Sat 21. Oct 2023 22:10:43
by mcfast
I am really not good with this PC stuff, I tried to download the files and I can't do it, if someone wants to do a screen share setup, give me a time and date and I'll set everything up, maybe we can get the information you need that way, if not, I will send the unit in, to Spirit to get a look at, I will pay the shipping it is better then a non-functioning unit.
Thanks John
Posted: Mon 23. Oct 2023 17:14:26
by Mattes61
Hello that's not rocket science, look at this:
Follow these steps:
Click on save
Enter a name
Click on save
Now in this folder is the file, here in my example C:\Program Files (x86)\Spirit Settings
That's all !
Posted: Thu 26. Oct 2023 12:19:57
by mcfast
All is good, it was the setup, me bad.
