Spirit GT Speedsensor
Diamondblack
Hello!
Will mount a spirit GT in my Turbine. Actually have a CGY on it but the Spirit ist my Fav!
Will the Futaba Speedsensor (magnet) work with the GT?
THX
yes, it will work. However we recommend using our Spirit RPM sensor which has more clean RPM signal.
Diamondblack
Thx for answer. When you say it will be better and clean signal than i change it.
Have allready one at home.
Diamondblack
One Question more.
I have two magnets in my flywheel. One ist north and one is south.
How much should i select in the spirit. 1 or 2? Sensorpoints?
It is recommended to use two active magnets as described in our manual.
If there is 1 active magnet then set Divider to 1.
