[ Version 3.6.0 released! ]
New version 3.6.0 released!
  • New OMP M4 ESC telemetry support:
    • Full support for OMPHobby ESC telemetry.
    • See wiring and settings at the Wiki page
  • New Spirit Settings software look:
    • Spirit Settings is running atop new GUI library for all Operating Systems.
    • You can access Manual pages easily by clicking at the left Panel icon. It will open corresponding manual page depending on Tab that is selected.
    • You can open Forum for asking a question directly from the software now.
    • Spirit Settings software will show you an important Event at the Connection tab without opening Flight Log.
  • ESC telemetry in the Spirit Settings:
    • Spirit Settings can display ESC telemetry values directly in the software now - Advanced/ESC Telemetry window.
    • All telemetry enabled ESCs can be interfaced with Spirit units also with Radio System that has no telemetry support.
  • Enhanced Spirit RX receiver support:
    • Full support for Spirit Radio System.
    • Wave Receivers can be easily flashed from the Spirit Settings software.
  • Full support for upcoming Spirit W1 units:
    • Brand new Spirit units with integrated Wave receiver can be used from this update.
    • Spirit W1 can be also used with all other external receivers - same as standard Spirit units allowing easy transition.
  • Rescue - Automatic:
    • New parameter Rescue Automatic - Duration.
    • Parameter can control how long the Automatic Rescue will push the model upwards after reaching Rescue Altitude.
  • GeoLink - Altitude Limit:
    • New parameter Rescue Automatic - Duration will affect also Altitude Limit function.
  • GeoLink - Position Hold:
    • Position Hold was improved for easier steering.
    • Sticks Priority parameter will affect steering rate now.
  • GeoLink v2 module - Static discharges:
    • GeoLink v2 modules are much more tolerant for a static discharges now.
    • In case of major event when module can't operate automatic recovery will trigger and it will continue in operation without interruption.
  • GeoLink v2 module - Logging:
    • Fixed random logging problem when Log entries were missing.
    • When module is logging in the air Blue Status LED will be flashing each second.
  • GeoLink v2 module - Connection:
    • Fixed random inability to enter the GeoLink HW settings and Map data in the Spirit Settings.
  • GeoLink v2 module - Altitude measurement:
    • Altitude will not reset from now.
    • Instances when it was resetted during flight causing imprecision of Altitude related features are avoided.
  • Spektrum SRXL2 major changes:
    • Spektrum SRXL2 support was improved to better operate with multiple SRXL2 receivers/satellites connected at the same time.
    • Spektrum Integration and Telemtry can now work without interruption from any SRXL2 receiver or satellite.
    • When signal is lost there is no delay when switching to other active receiver.
  • Spektrum SRXL2 receiver binding:
    • Spektrum SRXL2 receivers and satellites can be all bound by pressing CTRL + B shortcut when running the Spirit Settings software.
    • Receivers that were already bound can be left without any change. No need for repeated binding.
  • Spektrum Integration:
    • Integration menu will be not blank after prolonged inactivity period.
    • Added missing ESC telemetry options in the menu.
    • Added missing Stabi/Function options in the menu.
  • HoTT Integration:
  • Added new protocol JR XBUS mode A:
    • Brand new protocol for native support of JR XBUS receivers.
    • Telemetry support will be availble in next updates.
  • HobbyWing v5 ESC telemetry bug fix:
    • Fixed current and capacity measurement with certain 150A v5 models.
Update for the Spirit units, GeoLink v2, Wifi-Link, JETI integration is available for download.
NOTE: No settings changes are needed after update from 3.5.0.
We released new update for GeoLink v1 modules right now.
There are slight improvements in the performance and also connection stability.
