[SOLVED] 3.6.0 on Linux
MegaHz
I can not execute settings.sh on Linux Mint for some reason. Also unable to install directly from terminal.
Please try to download this ZIP file, extract the archive into the spirit settings folder - there is new settings.sh for launching the software.
I hope it will help you.
If not, please send me output from the terminal that you can see after starting the spirit settings.
What version of Linux Mint do you have? We will try it now on clear installation.
settings.zip
(524 Bytes) Downloaded 154 times
MegaHz
I have Linux Mint Cinnamon. The therminal will open and close immediately when I try to execute the file. Yes, all files were unzipped to a folder.
MegaHz
Just tried that. Settings.sh will not open when try "Run" or "Run in Terminal"
MegaHz
My bad. I overlooked the attached ZIP file you provided. Yes, it WORKS now! Thank you very much for your help.
Perfect, the fix will be available in upcoming update.
We are glad for each Linux user ;)
MegaHz
ZeXx86 wrote:Perfect, the fix will be available in upcoming update.
I know exactly what you mean. Don't get me started to write about windows..... :D
