[SOLVED] V 3.6 nearly unusable on the latest Mac OS
krm97
I have a 2020 Macbook Air with the latest software release Sonoma 14.1.2
My Spirit software crashes 3-4 times before I can complete a setup. In many cases I have to reboot the system to get it to work.
I think that there is a major bug in the latest V 3.6 release that needs to be immediately addressed.
ajadda
do you use a WiFi-Link?
My expirience is the same when using WiFi-Link, but using USB I have no more crashes or disconnects.
That is at least a workaround for those of my setups where the sys-port is reachable without disassembling parts.
Regards,
Alexander
It seems there is problem with no internet connection scenario.
It is not related with Wifi-Link but when using Wifi-Link then you might loose internet which causes the problem.
Today we found the issue and fixed it.
You can test new version before we will release it:
https://spirit-system.com/dl/settings/s ... .1-mac.dmg
ajadda
works for me, thanx a lot!
Regards,
Alexander
