Acro Delay and Rescue Automatic Duration
Konrad
I have a question: Is the acro delay included in the rescue automatic duration? Does rescue automatic delay always have to be longer than acro delay? What happens if rescue automatic delay is zero? Does the helicopter then turn from inverted flight to normal flight in the rescue case?
rescue automatic duration parameter was there all the time, except it was fixed to 1.5s. Now you can configure it. But all the rest is working identically.
No - when acro delay is set then rescue is finished only when model is skids down. So the time is counted from upside down position.
As you can see in the software this can't be set to zero
Yes, if Acro Delay is set.
