micro Spirit wiring SRXL2 specktrum
atamargo
Dear Guys
I am new with Spirit FBL and i want to start with size 250 helicóptero and micro Spirit with radio master
I not Sure how to aire the Spektrum SRXL2 to my to micro Spirit.
Some one can help me?
You can order SRXL2 Adapter with Order message - for microSpirit.
Then we will send you special adapter that will fit to your unit without any modification.
This is the the best way. Alternate solution is to get Spektrum SRXL2 satellite adapter which can be connected directly at the SAT port.
Radiomaster can not handle SRXL2-Protocol only DSMX is possible (for example two of the SPM9745-satellites) -
atamargo
Upps :o :o i don't know that the SRLX2 is no for radio master. And way, Wich is the best way for conect the microspirit with radio master?
Thanks in advance
you can see at http://www.multi-module.org what protocolls are possible -
other protocolls look here:
https://www.multi-module.org/using-the- ... etails/dsm
https://www.multi-module.org/using-the- ... s/frsky-x2
https://www.multi-module.org/using-the- ... ails/sfhss
For this little heli I think there is no teletmetry necessary so that you can take DSMX-Receivers (one or two) or you can take an SBUS-Receiver (FrSky) -
The wiring of the spirit look here:
https://manual.spirit-system.com/index.php?title=Wiring
atamargo
ZeXx86 wrote:Hello,
where i can order from USA?
HeliDirect is our USA dealer. But microSpirit can be bought only in our eshop - few last pieces. Then they will be replaced by new model.
atamargo
ZeXx86 wrote:HeliDirect is our USA dealer. But microSpirit can be bought only in our eshop - few last pieces. Then they will be replaced by new model.
I bought the micro Spirit from helidirect
I need some options for the Receveir and radio master tx16.
I test the Frsky xm plus but i have problems for bindig with radio master. I don.y know is possible for conectó with the specktrum satélite SRLX2, some one wrote that these receveir not work with radio master.. Wich is the best option to bina with radio master Tx 16s??
Use Radiomaster receiver with Radiomaster transmitter.
Or use at least FrSky ACCST receiver. Using other receivers is not good idea, because all the features are supported only partially.
atamargo
[qDear Guys
I want to Connect the Frsky XRs or Xm, but when i am on the wizard and try to use and of those receiver, the System tell is no soportes for microspirit... How/what i can do?
