new heli, new problems
Posted: Tue 23. Jan 2024 22:56:10
hi guys!
so i built a new heli again 700trex pro with md500e fuselage and 5blade roban head
i spent a week now findin out why my swash isnt working properly. what ever i did, im flyig sideways.. and adding 50degree phasing is correct diret\ction, but rear blade is moving over the tail
that was sorted out now.. hanged from 120ccpm to 140ccpm, and 50degree phasing!
B U T!
trying to take off in stabi scale or coaxial mode is just imossible. heli wants to turn to the side or nose up extremely.. i just cracked my tail rotor..
why does this happend? my heli i 00.1 degree rear tilt and almost 00.1degree side tilt. CG is spot on
but i just dont have the balls som try to take off since the heli is very uncontrolable.. i have identical settings to my 2 blade 230
stabi scale, control rate at 2 or 3 an i can take off anytime anywhere, eve in my garage.
with the md500 its total chaos.
i also feel its very little movement in the swash when i try to tilt it.. all tho im very confused regarding the swash movement. im used to 0 phasing and 2 blades, it goes just fwd/back and to the sides.
this one in angle...
anyone having same issue with latest update maby? or is my setup still wrong somehow?
B U T!
