Hi, I have a question about the 6 degree geometry tuning.
I get 6 degrees with the blades parallel with the boom measuring from the back of the heli.
However, if I measure from the front, I only get 5.2 degrees.
Witch one do I believe?
Swash is level, zero pitch when servos at 90
Thanks.
please make sure that when ticking Subtrim (tuning) menu all servo arms are in the center and there is 0° between main blades.
This might be not equal as when your collective pitch stick is in the middle. For this reason it is good to verify first.
What is your current value for Geometry 6° when you can see 5.2°?
Then increase the Geometry 6° value and you will reach to 6° instead of 5.2°.
Both readings should be same, just opposite.
When you will measure -6° in front you will get 6° at the back (on the other blade).
If your servos are indeed 90° to the main shaft, then it sounds to me like your swash is not perfectly level.Grant86 wrote:I just bumped it up to 90, now I get 6° when measuring from the front but I get 7° from the back.
The servos are at 90 when in subtrim (tuning) and also have 0° on both blades .
