Spirit unit not operating in stability
limabean1
Can someone help me please.
The spirit unit in My 450 scale is not operating in stability mode even though I'm pretty sure I've set all relevant to setting and fbl settings right.
-60 gyro etc. It's functions like a flybared heli.
Ta
please attach you settings file so we can check how your unit is configured. Without it we can only guess.
limabean1
Thank you, I'll get settings and get back to you..ta
Driveline651
limabean1 wrote:Can someone help me please.
Ta
Are you able to see it enabled and then engaged when you look at the diagnostic page ?
If not you need to get it enabled in stabi page . And if you follow the spirit online manual it should walk you through it .
If it’s set up right you will see “enabled” in the area under the green bars on the diagnostic page , then when you activate it it will change state to a blue “engaged”
