[ Version 3.6.2 released! ]
New version 3.6.2 released!
  • Spirit Settings - Configuration:
    • New configuration window can be opened by pressing left bottom icon.
    • You can find Wifi-Link module configuration there.
    • There is new Window Scale ratio configuration under Windows and Linux.
  • Spirit Settings UI improvements:
    • Added support for HiDPI displays. You can configure Spirit Settings window scale ratio in the configuration now.
    • If using high resolution you can make whole software window including fonts much bigger.
    • Backup tab has changes in button naming to make it more clear.
    • UI and configuration should be smoother now.
  • Spirit Settings - Wifi-Link:
    • Connection stability was improved with Wifi-Link.
  • Spirit Settings under Windows:
    • Improved stability of the software on certain computers. Fixed random crashing of the software.
    • Spirit Settings app is fully 64bit from now.
    • Installation Wizard will automatically detect if Operating System is 32bit or 64bit. It will install a proper version immediately.
    • In the Configuration window (About Tab) you can see 32bit or 64bit label.
  • Spektrum SRXL2 improvements:
    • Fixed telemetry and integration problem with Spektrum SPM9747 satellite when using with multiple SRXL2 receivers.
    • Manual Binding will work on all SRXL2 receivers and satellites now with CTRL+B shortcut.
  • Spirit GeoLink modules:
    • Fixed detection of the Spirit GeoLink modules affecting mainly GT and GTR units with no GPS/GNSS signal.
Update for the Spirit units is available for download.
NOTE: No settings changes are needed after update from 3.5.0, 3.6.0 or 3.6.1.
