Hi
can you give me some paramaters in order to feel the flight style I used to had with IKON in a standard 3D type flight?
The heli is a original kit of align trex 600L dominator, it has High voltage servos
thank you very much
TREX 600l DOMINATOR PARAMETERS HELP
you can try to set Flight Style to 1-3, Cyclic Feed Forward to 5-6, Cyclic Rotation Rate to 9-10.
related to the parameters?
I have rudder servo limits: minimum 167, maximum 215. do you think is a good idea to move ball linkage to a further distance in the servo horn?
and about parameters of rudder is ok rudder delay at 10, rudder dinamic 6 and pirouette consistancy at 168 ?
I have cyclic gain at 55% and rudder common gain at 1.2x, thats OK ?
remember, I fly 3D at the moment, NOT HARD, I am just trying to do hurricane and funnels, but not succes at the moment..... so, this is way I asking some help in order to get the best confirguration in order to better advance in my flying skills....+
thanks a lot again
thanks a lot again
With PWM you have to unassign Gyro function in the software and assign Channel 5 to Bank function.
Then you can set the Gyro Gain in the Sensor tab and Bank switching is performed through Gyro channel. The best is to use tri-state switch.
Your parameters seems to be OK, but it is hard to tell you what is the best for you.
If you can see that something is not working correctly, then you can describe the problem and I can help you.
What is your rudder servo?
You can maybe increase Cyclic Gain to 60 - 65% and put the ball linkage to a further distance, since your limits are quite high.
I recommend to set Rudder Delay to 0 and Piro Consistency could be maybe even higher if the rudder does not hold perfectly.
HI
TODAY I TRIED TO MAKE SOME FUNNELS WITH HELI NOSE UP BUT TAIL DONT HOLD POSITION AND KICK CONUNTERCLOCKWISE.
ANY RECOMENDATION?
I AM USING
FLIGHT STYLE 2
GYRO 61%
CYCLIC GAIN 60%
RUDDER COMMON GAIN 1.20X
CYCLIC ROTATION SPEED 9
RUDDER ROTATION SPEDD 8
CYCLIC FEED FORWARD 6
RUDDER DELAY 0
RUDDER DYNAMICS 6
PIROUETTE CONSISTENCY 175
I AM ATTACHING FLIGHT LOG
THANK YOU FOR YOUR ADVICE
ANY RECOMENDATION?
I AM USING
FLIGHT STYLE 2
GYRO 61%
CYCLIC GAIN 60%
RUDDER DELAY 0
RUDDER DYNAMICS 6
- Attachments
- spirit-log-2015-04-19-230703.pdf
- (81.64 KiB) Downloaded 116 times
Could you please send your settings file too?
Is gyro gain configured to max possible gain before tail wag occurs?
