Hi, i installed 3.6.2 and i tried to load a .4ds file saved in a older version and nothing happens.
It's using SRXL2 and the menu stays in PWM and i don't get any error or the file is not converted to the new version. I am sure i was able to load saved version in demo mode to look at the settings.
Did i miss anything. I don't know how to grab a older windows version to test.
Thanks i uploaded my saved file
Win version 3.6.2 not Loading saved versions of .4ds
- Attachments
- 2juil12-23.4ds
- (255 Bytes) Downloaded 155 times
the settings are not loaded in Demo mode only in 3.6.2, because there are bigger differences inside from 3.6.1.
However in 3.6.3 it will work again.
With connected unit you can load settings normally with all versions.
Thanks Thomas for the reason,ZeXx86 wrote:Hello,
Will the old files be upgraded when loaded in the 3.6.3 version or I should keep a old win version if I want to o back and check a setting. I really use that feature to see changes it my settings.
Envoyé de mon iPhone en utilisant Tapatalk
