spirit gt pwm
Posted: Thu 28. Mar 2024 17:37:39
by franz88
I would like to use spirit gt with receiving pwm
but I didn't quite understand the wiring
aux2 = bec
aux1 = gyro gain
rudd = rudder ch
elevator pitch aileron
https://manual.spirit-system.com/index. ... =Wiring/it
rpm sensor pin pitch, but pin pitch is used for the governor or elevator pitch aileron? (https://manual.spirit-system.com/index. ... overnor/it)
I have to connect the receiver radiomaster r88 v2
https://www.radiomasterrc.com/products/r88-receiver
if not is possible in pwm I can also use sbus
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 18:11:23
by franz88
Zexx86 ny radio not is access
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 18:19:19
I know :) We are testing with this radio for years and know it very well.
If you like your heli, dont buy this receiver.
Buy at least what I recommended to you.
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 18:27:45
by franz88
I was wrong I bought radiomaster r88 v2 thinking x6r is acces but not is acces is accst and I I thought it means access.
But with 6 channel how can I use rescue autkmatic, rescue normal and return to home ?
ok I'll buy what you say but 6 channel they are not enough.
Minimum 8 is exact ?
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 18:40:00
by franz88
https://shop.jonathan.it/it/444571-frsk ... telemetria
Is good?
X6r it doesn't have a few channels for altitude limit, rescue normal and return to home?
I spent 30euro why I bought radiomaster r88 v2 but if you you say it's not good I spend 60 euros and get the x8r.
tell me what I have to do I bought the r88 v2 but I have to be able to use
Governor
Altitude limit (spirit gt)
Rescue
Return to home (geolink)
I can give up the gyro channel and 8 channel is good
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 18:53:18
R88 costs only 11 EUR normally.
X6R will transfer all 16 channels, not only 6.
You can use even R-XSR to transfer all channels.
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 19:26:44
by franz88
ZeXx86 wrote:R88 costs only 11 EUR normally.
in italy things cost twice as much, I got it from an Italian shop so as not to wait too long.
in italy x6r it's not found but I found X8R
I buy x8r (x6r not available) is good x8r??
to connect it sbus at spirit gt do I have to buy some cables?
Re: spirit gt pwm
Posted: Thu 28. Mar 2024 21:08:17
by franz88
If I use frysky x8r with sbus on spirit gt i set futaba sbus mode ?
