BT disconnect issues
Baedarlboo
Using a Samsung Galaxy S4 and the most current Spirit app (happened with previous version too). There are times when I make changes and disconnect, the spirit will still sit there with the light blinking like it's still connected. I double check the phone and it's still disconnected. Only way to sole this is to reboot Spirit.
linux-user
Baedarlboo wrote:the spirit will still sit there with the light blinking like it's still connected.
My Spirit has always solid light, no matter whether connected to BT or not.
The only time my spirit is blinking is when initializing.
Probably you have enabled some special function and it was not disabled. For example Piro Optimization settings.
Baedarlboo
ZeXx86 wrote:Probably you have enabled some special function and it was not disabled. For example Piro Optimization settings.
Not sure what settings are considered special, but I wasn't in piro comp. Doesn't happen often, but it's done it a few times where I hit disconnect on the phone and it states disconnected but spirit is blinking and I have to power down and reboot. Nothing major, just something I noticed. Next time it does it, I'll take note on what exact setting function i was using.
error414
What do you mean "disconect"? Right way is disconnect phone over "disconect" button on "connection" screen.
Logo 600 3D -> Spirit FBL
Spirit settings Developer
