[SOLVED] Spirit and flybar
flybar1947
I would like to ask if anyone has tried the Spirit with flybar.
In my 450 works well the rescue but the stabilization does not work, it may be because I have the flybar? Has anyone tried it and it works even stabilization?
Of course I checked, did not save it as fact, is wrong
Thanks, regards :mrgreen:
both stabilisation and rescue modes should work without any issue with flybar.
It has to be only configured correctly.
Can you describe me the problem with more details?
flybar1947
ZeXx86 wrote:Hello,
I enabled the memory banks, controlling their activation in Diagnostic
In bank 0 = assigned Rescue
In bank 1 = assigned Stabilization
I saved each bank.
Getting up in the air with the switch in bank 0 = ok the rescue
With the switch in bank 1 = does not keep the commands, if I give a command such as forward or side he keeps in motion does not settle in hovering. It's like if I had not selected the stabilization.
I also tried to select the stabilization in bank 0 but behaves the same way. Something wrong?
I tried both with the switch of the Gyro with the value +/- activated or not.
you have to see in the diagnostics tab HF instead of HL in Gyro function.
Make sure that your Gyro Gain is negative for the stabilisation too.
Probably Stabilisation mode is not activated at all.
flybar1947
ZeXx86 wrote:Hello,
Sorry, just this morning I discovered a problem with the switch .... ok it works !!
I would still ask:
Why am I always log in and several times MAIN LOOP HANG OCCURED. I have a SBEC 20A.
Why am I even Limit rudder ... although the slider tail reaches absolutely the two extremes. For the flight goes well, however, appear to me these messages.
Many thanks
