Spektrum SPMAR10100T
Storchy
i am new to Spektrum, my first Heli.
I want to use Spirit GT with Geolink V2.
I want to control Heading Hold, Bank Switching, Rescue or AutoRescue, RTH over the Spektrum NX10
In addition i want switch off the 1st Buffer-Pack 50F v4.81 over the tx.
Is the SPM AR10100T the receiver which i have to use.
Thank you for your help
Ciao
Jörg
ExCCHP
An AR6610T would be enough
It's more about the channels of your Tx. You would need a 10 Channel Tx like the NX10.
Storchy
Thanks for your answer.
I understand it not really.
Has the AR6610T intern more than 6 channel and only for 6 channels the pins to outside?
I think i need 10 channels inclusive Nick, Roll, Pitch, Rudder and throttle
Ciao
Jörg
basically all receivers can receive all radio channels and send them through digital bus.
Physical channel output ports of the receiver do not equal to channel count it can receive and process.
So yes, AR6610T can send all channels your radio has to Spirit unit. Channel output ports are unused in any case, so it does not make sense to buy bigger receiver.
Storchy
Thanks a lot Tomas for your answer
Ciao
Joerg
