[SOLVED] Rescue is invertet
Voodoo2
I take all settings with the spirit. If I use the rescue funktion (Gyro -100%) the swashplate goes down, so its invertet.
Do you have an suggestion to change this behavior?
Regards Jens
yes, you have to configure Collective Pitch for the Rescue to the opposite side - negative values. For example -60%.
Voodoo2
I dont understand. The gyro value ist +60 HL (Heading Lock) and for Recue is -100%. If I invertet the gyro its no more heading lock.
Yes, but I am talking about Collective Pitch for the rescue, check the Stabi tab in the software.
Voodoo2
Ah thank you :D
