Hard Deck Settings
euwan
I just went out to have a flight with the spirit gt on a trex 500 forgot how much this system could do. The issue I am having is that when I am enabling Hard deck the helicopter just wants to keep climbing. Hard deck use to be set to about 10m in the software then I updated the module and for some reason it got set to 0
from my understanding you can use 0 to set the inflight hard deck anyway so I left it as that but even so when activating 10m off the ground it still just wants to climb. I have now changed the value to 10m and set the upper limit to 60m, is there anything else i need to do , not sure if i should be setting geo fence at the same time also?
Also how do you use the 3d player in the logs?
