Collective operation problem
Fly inn
Setup, GTR, Piuma heli, Jeti ds12, new Hobbywing 150 platinum. I have Throttle cut setup. When switched on, I have no collective. And servos move up and down erratically every few moments. I have aileron, elevator control. Connected to GTR w/computer shows collective movement on servo screen when throttle hold is on. Collective set up for throttle hold in ds12. Graph shows movement, standard curve. Idle up 1 collective works. But, idle up 2 and 3 also prevent collective movement, with throttle cut off. I'm at a loss. I have set up different rpm for each mode and it works fine. Rpm telemetry on ds12. I went back thru my setup menu, servos all correct hz and freq. Rechecked collective,,all smooth operations. End of setup, ready to fly. I did not mention it before, but, every few tests everything works perfect. Collective perfect all 3 flight modes. Operate throttle hold, perfect collective. Then all problems start again. Checked all wiring.
HeliMLM
is it possible that you have rescue activated at the same time? pls check in diagnostic tab that there is no "special mode" like rescue activated due to bank switching or whatsoever...
cheers
Michael
Fly inn
Thank you Michael!!!!!!!! That was it. Rescue was on automatic. As soon as it was disabled, all proper function was restored immediately. Thank you again.
HeliMLM
:D
cheers
Michael
