[ Version 3.7.0 released! ]
Posted: Thu 06. Jun 2024 13:40:31
New version 3.7.0 released!
NOTE: After update verify Sensor/Rotation Rates.
- New Spektrum Avian ESC telemetry support:
- Full support for Spektrum Avian ESC telemetry.
- Only Spirit GT, Spirit GTR, Spirit W1 are supported.
- Spirit Pro, Spirit 2, Spirit RS and microSpirit will be supported shortly after.
- See wiring and settings at the Wiki page.
- Full support for CRSF/ELRS telemetry:
- Spirit units are able to send telemetry now.
- Available sensors are:
- Battery Voltage
- Battery Current
- Used Capacity
- Vibration Level
- GPS Latitude
- GPS Longitude
- GPS Speed
- BEC Voltage (reported as GPS Heading)
- GPS Satellites
- Altitude
- Support for pure Flybar Rotor Head:
- Spirit Settings has new parameter Rotor Head where you can select:
- Flybarless
- Flybar (Stabilized) - is equal to previous behavior with Flybar that has aid from Spirit in terms of more stable flight.
- Flybar (Classic) - Flybar mechanics without any aid from Spirit.
- Flybar (Classic) mode will offer identical flight behavior as without Spirit unit - no Swashplate Gyros are used. However Rescue and Stabilisation modes can be still all used.
- YGE telemetry:
- Telemetry hang was fixed with certain models of YGE ESC and Spirit GT/GTR.
- Rotation Rates can be set in a decimal step:
- From now you can set Rotation Rates more precisely in the software and radio integration.
- Range is identical for both Cyclic and Rudder.
- Graupner HoTT telemetry:
- Spirit units will accept telemetry from Graupner HoTT ESCs configured as GAM, EAM and ESC sensors.
- Previously only EAM sensor was supported.
- UniSense-e telemetry support:
- Spirit units will accept telemetry from UniSense module configured as Graupner HoTT now.
- Using HoTT ESC will give you the most telemetry variables.
- Spektrum and HoTT Integration:
- You can set OMP M4 and Spektrum Avian telemetries from the integration menu now.
- Throttle safety Locking feature:
- From now Spirit unit will set Throttle to Low when Spirit Settings software is configured.
- This will prevent Motor to spoolup by mistake during configuration.
- When Throttle Hold is disengaged user is notified and asked if he wish to spoolup the motor.
- RealTime Logging:
- Battery Voltage can be logged from now.
- When Throttle Channel is assigned Logs are recorded only when Throttle value is above treshold.
- Logging is not triggered based on Vibration Level but based on Throttle value - if Throttle Channel is assigned.
- GeoLink firmware 1.4.1 update:
- New safety protection - GPS Satelites are set to 0 in case GNSS module will stop to respond for whatever reason.
- If module has internal malfunction only in one part Spirit unit will no longer use outdated data.
- Rudder Common Gain:
- Common Gain range was increased to 2.5x.
- Useful for big Scale RC models.
- FrSky EthOS integration:
- Integration script is compatible with EthOS 1.5.7+.
- Interface was improved and new options were added.
- New support for Log Viewer.
- Lua Script is Open-Source from now and licensed under CC.
- FrSky F.BUS protocol:
- MicroSpirit units can use F.BUS protocol with FrSky integration cable.
- FrSky Integration cable for microSpirit is recommended.
